Nextelbuddy
Thread starter- Joined
- May 4, 2020
- 165
Alpha 1 Gen 2 outdrive.
Had no leaks last August changed out the water impeller and the seals and then when I remove my outdrive to replace my engine I saw drive oil leaking out of the water inlet pickup in the lower unit.
Yes I know I'm supposed to pressure test the system I've seen YouTube videos I need to make a pressure test or I just don't have those tools right now.
More than a few places I've looked have mentioned that if you gear oil leaking out of the lower unit water pickup then it's most likely your carrier assembly that's under the water impeller.
So I bought one mercruiser it's a large yellow carrier assembly.
I went to separate the top unit and lower unit today and I was wondering if anybody could take a look at these pictures and tell me where they think the oil could be leaking from?
I can't tell if it's in the carrier assembly or if it's the seal up in the upper unit where the pinion goes in.
Remove the water pump and the ceiling plate to look at the carrier assembly and it looks like there's a bunch of drive oil in there so is it possible the drive oil leaked all the way from there up into the pinion area?
