Outdrive info
SPOONMAN1
I was wondering how I could learn the differences between the outdrives Merc. makes, I know the years give them different names, but are there different names for different sizes? I would like to reseach for a swap from cobra. thanks
mthieme
Re: Outdrive info
My mechanic was putting a bellows kit on my Cobra this summer when he informed me that an Alpha would bolt right up.
SPOONMAN1
Re: Outdrive info
Ok, but is an Alpha compatable with a big block and a 4 cylinder? Im Looking for the best replacement for a 95 King Cobra on a 7.4L.
Re: Outdrive info
Ayuh,......
Bravo is the Only answer for a BBC.....
SPOONMAN1
Re: Outdrive info
I kinda thought that but didn't know. Does the I -II-III represent older vs newer models?
Fishermark
Re: Outdrive info
When Bondo says...
Ayuh,......
He is right. But not because the Alpha would not fit. It's just that the Alpha will not hold up to the torque and horsepower of a big block. Mercruiser put them behind the big blocks for a short time, but found they were getting destroyed in short order. Your best best is a Bravo... but yes, an alpha will fit.
