outdrive id
coop60
i have purchased this boat that has no apparent id # on it . It has a chrysler slant 6 as a power plant with what i think is a volvo penta outdrive. I am trying to pinpoint what outdrive it is. All i have is the patent#2977.923 and this PZ NR 214450 number. can anyone help with model and year.the engine serial # is 109415. and if anyone can identify this boats make and year it shure would help
Don S
Re: outdrive id
Volvo never used a Chrysler slant 6 that I am aware of, and I've been a Volvo tech for a lot of years. Might post some pictures of the drive and engine to start. The PZ number is too old to track down without a little help in year of boat or pictures.
coop60
Re: outdrive id
maybe these will help thanks
Fishermark
Re: outdrive id
That is old! I can't help with your id. Don or someone will chime is soon.... but I would suggest getting rid of the inline fuel filter. That's a safety concern.
Don S
Re: outdrive id
That is an AQ200 outdrive. I did find the range of PZ numbers on the chart for both the 200 and the 250. I knew by looking it was one of them, but the numbers told the story.
I do have an OEM service manual download for the drive, http://www.4shared.com/file/123189408/3fa55eb3/200_drive.html
Nothing for the engine, what kind of boat is it? I know Glastron used different engines attached to volvo drives.
Alpheus
Re: outdrive id
That boat looks to be in real good shape for the age, and a slant 6 is the best engine I have ever owned. Ever! They just dont make engines like that anymore. That thing should last for a long time if it was taken care of...
coop60
Re: outdrive id
thanks 4 the replies. but Don the aqwa200 download you sent has a power lift on it and mine dosen't other than that are they the same outdrives
sqbtr
Re: outdrive id
What is the turnbuckle and chain holding?
captmello
Re: outdrive id
The 200 has a mechanical lift, like pictures in the manual, Thanks to Don for the link.:)
It looks like you do not have one as it would be visable behind your starter, mounted in the flywheel cover. Do you have a plug in the hole? Its about a 3/4 inch hole on the port side of the flywheel cover.
