onesNzeros
- Jul 27, 2011
- 15
So at the end of the last boating season, several of us took our boats on a pretty lengthy trip. On the return trip we were cruising at about 3k RPMs and I started hearing this whining noise over the stereo. By the time I got the stereo volume turned down to listen to the noise more closely, I lost all forward motion. I pulled the throttle back to neutral and the engine was was running fine. I put it back into forward and began hearing a clicking noise. I put it in reverse and it went backwards as if nothing was wrong... no clicking from the outdrive. I put the boat back in forward and clicking again but the prop was apparently spinning because the boat would go forward but only at a snails pace. I pulled the boat over to the beach so that I could inspect the outdrive and verified that the prop does indeed spin in forward gear. I decided to go ahead and replace the prop with my spare in hopes that it was just a spun prop, but unfortunately that wasn't the problem. I had a friend tow me to the nearest dock. What a way to end a boating season!
Knowing that I wasn't going to have any spare time to work on the boat any time soon, I winterized her and put her away for the winter. I'm going to get her out this weekend to try to troubleshoot this problem and wanted to check with you knowledgeable people for thoughts and suggestions before getting started. Help?
This is an Alpha One Gen 1 outdrive with a merc 5.0
