outdrive antifouling? what to use?
Shaun78
petit alumaspray or the interlux outdrive spray or should I use the interlux trilux 33 and brush it on? I boat in salt water and will be leaving the boat in the water. I have heard that the spray cans don't work well.
JCF350
Re: outdrive antifouling? what to use?
No paint and keep bottom (hull) paint 1 inch away from outdrive. Keep outdrive clean with elbow grease.
Shaun78
trilux 33 has copper in it but it is made for aluminum outdrives. will it cause any corrosion?
rodbolt
if it contains copper and you use it on cast aluminium in salt water it WILL cause corrosion.
stick with a tin based and keep all other paints at least 1" away from the drive.
the warmer the area the worse the corrosion is.
in my area I have seen holes eaten into pontoons and drives even after an epoxy barrier coat.
if in doubt contact the paint manufacuer by E-mail for product compatability and application procedures.
this is something I do see a lot of.
Shaun78
interlux trilux 33 is made for aluminum and outdrives but i think it has 24% copper. I could be wrong but it is made for aluminum.
Chris1956
Shaun, Use the Trilux on your outdrive. It is made for aluminum, however you must have sufficient primer and paint on the outdrive before applying the Trilux. Read the Trilux instructions.
Shaun78
I sanded the drive and used primocon primer and then I used petit alumaspray. I hear that the sprays don't work well so I was thinking of putting 1 coat of the trilux over the alumaspray. I will laquer thinner the drive 1st.
