Outdrive Anti-fouling paint
CascoBay
I use Interlux Trilux Prop And Drive in the aerosol can on my Volvo Penta outdrive.
I read the can 2 times, but is there a time limit to when I can splash this after I paint?
I want to paint it as soon as I get it back together but it problably won't launch until a month or so later.
Is this ok? I know my hull bottom paint warns to only paint if your launching within 30 days.
Thanks for any advice. I have a great weather window approaching and would love to get this done, Maine weather is so up and down.
JoLin
Re: Outdrive Anti-fouling paint
I think you'd be okay, but you should try the Interlux web site, or give them a call to be sure.
Ablative Antifouling paints do not have time limits on launching. TriLux is ablative.
I also recommend you use up and ditch the non-ablative stuff you are using on the hull and get some ablative AF Paint next time. You can get two or more years out of a single application of ablative paint, and it is just a bit more $ than the single season stuff.
tkrfxr
What kind of outdrive, aluminum or composite (XDP)?
Aluminum drives may require prep.
