outboard won't go into gear
seasalt7713
I am looking to buy a used boat, but I'm told that the 150 hp Johnson motor does not go into gear. Is this Major or Minor to fix.
HighTrim
Re: outboard won't go into gear
Welcome to iboats.
That completely depends on what is wrong.
Remove the cables and try shifting manually. If it now shifts there is a problem is the cable which is the best case scenario. If it still does not shift, the problem is in the gearcase and is worse case scenario.
What is the model number? Check the compression. If compression is good and she runs well and you are getting a good deal on her it MAY be worth it depending on the issue at hand.
