It seems as though my outboard doesn't steer with a wide enough angle range after a new dual cable steering system was re-installed on my boat (19' cuddy with 1986 Johnson 150HP VRO). The previous owner had replaced it with a single cable, which let the outboard swing through a wider range. Right now, with the new dual cable system, it turns a total of 90 degrees (plus or minus 45 degrees).<br /><br />I'm worried this will make docking in tight spaces harder (at least with my meager skills).<br /><br />Is this range good enough? If not, are there longer lever arms or something like that available??<br /><br />I did try to go this myself, but gave up at let the shop do it, they picked the parts.
