Fl_Richard
- Jan 21, 2005
- 1,428
Re: Outboard mounted to high or to low?
nevermind
nevermind
The foot on the 135 i had on the boat put the prop right behind the bottom of the transom so from what i could figure was that the transom pushed the water away from the prop causing it to cavitate. I dont think it would be that much of a prob to get a used jack plate & raise this motor a few inches but i wanted to check & make sure it couldnt be left the way it is before i go spending more money. The vee in the transom is deeper than it looks from the pics so its misleading but thx again for all the input, after all im here to get advice from everybody cause im still new to boating & by no means know it all lol.
Looks like you have at least 3, maybe 4 holes to move the engine higher on the transom. That would be my suggestion, only expense would be cost of a tube of 5200 or some sealant to fill the bolt hole before re-installation.
