Outboard Motor Security in a public space
texasbowhunter40
Just got a new Tracker Grizzly on the cheap and need to mount my motor to it, unfortunately I have to keep in in a storage yard or in my driveway due to it's size, and was wondering if there is a good way of securing it to the transom to prevent theft.
I was thinking about using anti theft bolts but can find a source for them do any of you guys have any good ideas to protect my investment?
Re: Outboard Motor Security in a public space
Ayuh,.... A lock only stops an honest man, 'n merely inconveniences a Thief...
You should mount it securely, 'n make it as inconvenient as reasonable to removed...
A Padlock on the safety chain is pretty common,...
The special Key nuts are usually more of a problem for a Mechanic, then to a Thief...
'n remember,.... You're probably gonna be the next guy to have to remove it...
Personally, I'd go with a grease packed padlock.....
If ya make things Too tough to steal, a determined Thief will just steal the Whole darn thing, or Destroy it so bad, nobody get's it....
They will likely steal the entire rig rather than fooling with unbolting the motor. Storage is always a consideration when making a boat purchase. Unless it is stored inside, on your property, or under constant watch, it or its contents can easily disappear regardless how well you protect it. Coupler locks, antitheft locks on the engine mounting bolts, removal of the wheels, chaining to a post, etc are all protective measures and even then, it may not stop a determined thief. Consider Smith & Wesson and a big dog named Brutus.
texasbowhunter40
It is sitting under a security camera and I plan on it being insured against theft as well but I want to make them work for it.
Currently I have a tongue lock and an axle lock and its chained to the house inside the garage, I think the boat is as secure as it can be for sitting in the driveway, I'm just looking to secure the motor.
I have the smith and dog thing covered but the dog is kind of lazy and the operator of the smith has to work to feed the money pit in the driveway.
BonairII
With having insurance, locks, and a security camera....sounds like you have everything covered. The best advice I can give you, is to make sure the cover is always on it so no one actually knows what you have on/in the boat.
Casual thieves will be less likely to make an attempt, if they don't even have an idea if there's even anything worth stealing.
Hopefully, you insurance covers vandalism also.
Home Cookin'
If you have a crappy looking old motor they are less likely to take it. Also, remove the prop--so they won't steal the prop but also some will be less likely to take the whole motor in the first place.
Problem is, theives come in all varieties, adn what works against some won't work against all, and what works against (almost) all is such a pain or expense to you, that you become the victim of a crime that hasn't happened yet.
But one thing in common--they are all opportunists. First, they are attacted to what they see, so having stuff covered or out of sight makes a difference. Second, anything to slow them down is a deterent, so just like a hook on a screen door stops some who just just as easily yank it open, even a small hindrance has some value. So for the typical old motor in a typical neighborhood, a bike lock is sufficient.
There are the vandal-types who either damage or take stuff not for its value; not much you can do about them.
With rising gas prices, guard your tank, too. Gas has a lot more value to a lot more people than an OB.
And then there are the "borrowers" fellow boaters who forgot their own fender/lines/paddle/PFD and grab yours so as not to mess up THIER day. They should be keel hauled.
F_R
Any self-respecting crook has a pair of bolt cutters. A chain and padlock are useless.
I bolt my motor on with bolts that are a PITA to remove. But that doesn't prevent theft of everything else, or the whole rig. You might fabricate a long steel bar that goes through the spokes on one wheel and across to the spokes on the other wheel. Make it a PITA to remove also.
Cheap anti-theft bolt: A bolt with a hex-socket (Allen) head, and a self-locking nut. The crook isn't going to go home to get an Allen wrench. And the locknut makes it turn too hard to do it with pliers. You only need one of the mounting bolts to be that way. Likewise, on my kicker motor, I replaced one of the transom clampscrews with an Allen head bolt (actually a big long setscrew)
sutor623
This is genius!! What a great idea. I am going to order me some of these.
cyclops2
Banned
Make the bum steal the boat.
We put Carriage bolts thru anything removable. Then heavy spot welds on the threads & nuts
Make the bum bring a battery powered grinder.
If you are doing the rod thru the wheels. Weld end caps on.
Please buy a good right angle grinder. KEEP A CRUMMY Blanket TO STOP GRINDING SPARKS FROM ruining any nice finishes. thats all we can do.
When using a grinder. TRY to ALWAYS have the wheel ON TOP of the piece being cut. Sparks may need a blanket.
If you cut from the bottom UP ? The wheel can grab in the groove. Zip around the piece & jump up into the boat / motor & damage it.
Grinders kick up & back JUST LIKE A CHAINSAW DOES.
Rockmere1
Yes they can, have a nice scare from a 9'' grinder while working on a tank job. Be careful, cant really help with the theft part, but the carriage bolts sound good
River_Lizard
Pull the prop off before storing and anything else (trolling motor, depthfinder, batteries, etc..) it's the small stuff that can find it's way out of the storage area via other renters. And with it being stored for months, it might take you a month or so to realize something is missing off it and then it's going to be hard to go back to watch video tapes since a lot of places don't keep them that long.
I use to park my Bass boat in my apartment complex in TX. Every Sunday when I got home from fishing the weekend I'd pull the prop, pull the batteries, my trolling motor, fishfinder, etc.... it was a pain-in-the-A because I lived on the second floor. Those deep cell batteries weigh about 80 to 90 lbs and the S/S prop wasn't light either.
R Socey
Remember the good old days when you didn't have to lock the door? My solution is to cut a pinky finger off first offense, hand off on the second, head off on the third!
I had my boat at a boat yard - people would throw trash in it , turn my switches on - when not covered. When it was they would cut the cover to look in it. It's now protected with camera, dogs, and guns!
Tim Frank
With a bit of an improvement....
Drill and tap on center in the allen-head socket, and put in a small diameter set screw that is early full depth. Drill the matching hole in your hex wrench and you have a bit of extra security to thwart the odd scum-bag who has a few tools with him/her.
Bamaman1
You can buy security cables with loops on each end that a padlock can go through--at Lowes and Home Depot. They have a bunch of different lengths.
Bass fishermen use canvas boat covers, and they have alarm systems specifically designed for boats protecting their boats. Sign on to BassmasterElite.com and read Kevin Van Dam's recent note on his new alarm system.
