Outboard for an Outboard
CodyJColby
Hello,
I have a 40HP Tracker attached to my 1994 Bass Tracker Boat. I've got an old Evinrude 100 that I would like to replace it with. The current tracker is 2 cycle engine with seperate gas / oil. The current engine turns easily with the steering wheel and I'm concerned on how to replace the steering and throttle system... any ideas?
This is a first time project for me.
Thanks!
Cody
GA_Boater
Re: Outboard for an Outboard
What model '94 bass boat - they probably made 10 or more models? What's the rating plate say max HP is? Also a Tracker motor is just an OEM motor with Tracker labeling - Do you know the make like Mercury, etc.?
And welcome aboard to iboats.
CodyJColby
Thanks. I believe it's a pro 17, I'll double check that as well as the rating plate when I get off work. It is a mercury engine.
Thanks.
GA_Boater
Bob's post above is why I asked about the boat. That's going to be a lot more weight, not to mention 40 horses over max. Not a good idea.
