drewpster
- Oct 17, 2006
- 2,059
I need to put together a good battery setup for my tri-hull project. I need provisions for a radio and a trolling motor and maybe some lighting. Other than that the electrics are pretty standard. The trolling motor is a 40lb. thrust model. I was thinking of using a single start battery and a single deep cycle. I want to use a manual battery switch as well as a means to combine the batteries automatically. (if that is recommended for outboard setups) I am not a fan of diode isolators.
Since the none of the accessories will generally be used all at the same time, I was thinking of setting it up so that the start battery is isolated for starting only. I will run all the "house loads" off the deep cycle. During fishing, the trolling motor and maybe the anchor light will be all that is used at a given time. Am I on the right track here? The big question is how, or should, I combine the batteries while the engine is running. The manual switch will be used to transfer all loads back and forth as needed between the batteries. I prefer a system that combines and isolates the batteries automatically rather than keeping up with a manual switch. I am way too forgetful for that. Any suggestions? Should I combine a potentially dead battery with a full one on an outboard?
