outboard corrision
ggreenbe
The bearing carrier,where the propeller fits in, on my Yamaha 9.9 outboard became corroded.It was stuck in there,and the bolts that keep it in were corroded away and needed to be heated to be removed. The motor has electric start and and an alternator that charges the battery. I don't let it sit in the water when the boat is at the mooring.The boatyard mechanic has replaced the part but has said nothing about what caused this corrosion.A friend said that current must be leaking into the motor and causing electrolysis. Any thoughts? How do you test for this How would you fix it? Thanks for your wisdom. Gerry, At Last 26,Falmouth,Me
99yam40
Re: outboard corrision
Salt water, plain water, moist air from being on the water, rain, etc. will all promote rust/ corrosion if metal is left in it.
If motor if kicked up sitting at the mooring it maybe holding water in that area.
If it is in salt water, do you rinse it well with fresh water after use?
