I have a 1988 Mercury 90 hp 3 cylinder outboard. Last year a new water pump was installed with the new houseing and this year I installed a new water pressure gage. When I run the boat at idle at startup the water pressure is between 10 and 15psi. When I throttle the boat the water pressure drops down to 5psi. Then when the motor is warmed up the fluxuation in the pressure depending on the throttle position varies only slightly from between 5psi and 10psi. Can anyone explain to me why this is happening. I have a good pee stream shooting out of the back of the motor.
