Re: Outboard Charging.
It's not charging. The voltage does not change from not running to running. It just slowly drains the longer you run. I assume because its providing all the power to fire. I am going to see if I can find a service manual for this engine so I can test everything to see what the problem is.
Start with this:
Disconnect the battery.
Remove the rectifier wires from the terminal block, the rectifier is bolted to the side of the powerhead and has 3 wires and a seperate ground wire. Using a ohm meter, connect the black lead of the ohm meter to the rectifier base (ground), then one by one, connect the red lead of the ohm meter to the yellow, yellow/gray,
then the red wire (some rectifiers may also have a fourth yellow/blue wire. If so connect to that also). Now, reverse the ohm meter leads and check those same wires again. You should get a reading in one direction, and none at all in the other direction.
Now, connect the black lead of the ohm meter to the red wire. One by one, connect the red lead of the ohm meter to the yellow, yellow/gray, and if present, the yellow/blue wire. Then reverse the leads, checking the wires again.
Once more, you should get a reading in one direction and none in the other.
Note that the reading obtained from the red rectifier wire will be lower then what is obtained from the other wires.
Any deviation from the "Reading", "No Reading" as above indicates a faulty rectifier. Note that a rectifier will not tolerate reverse polarity.
