Out Drive Drain Plug Question
DayCruiser
Ensign
Ok might have gotten the plugs mixed up. 1990 mercruiser 3.0 Alpha 1 out drive upper and lower.
You have 2 drain plug screws. One looks like a regular screw and the other is a screw with a point on the end. Which on goes where? Out of curiosity, why does it matter?. I laid them both down together................Thanks in advance!
Re: Out Drive Drain Plug Question
Ayuh,.....
The 1 with the Pointy end, is a Magnet,....
It goes inthe Bottom, to collect Filings.....
DayCruiser
Ensign
Thanks for the quick response Bond-o. I appreciate the help! I will go see if I screwed it up. Not in the water yet.
