out drive clicking in trailer position
Chuck r
drive clicks while in gear in trailer position (Full up drive), would that be U-Joints or Gimbal bearing? Hav'nt noticed any noise in hard left or right turn, but when trimmed up will get some vibration, Bravo-3 with 7.4L
Thanks in advance for you help.....
Don S
Re: out drive clicking in trailer position
NEVER, EVER run the engine with the drive full up. You will probably damage either the transom shield, the bellows, or the outdrive itself. Possibly all three.
I would suggest you pull the drive and inspect for damage.
Ayuh,........
That's Why the Trim System has a built in Limit,.......
You're Not supposed to Run it when above the Limit.......
Ayuh,....... All of it......
cbavier
Why would you be running it at any time in the Trailer position? was there a reason?
Don S
Probably for the same reason you use your email address for a screen name, you just don't realize the problems it can cause. Bet you get tons of SPAM and wonder why don't you?????
cbavier
DonS
No I don't receive any spam because I have spam blockers but I sent emails asking for help on how to get my email address off. I have tried to no avail to remove it. If you know how help me get it off.
HT32BSX115
Your best bet is probably to create another user name possibly using "cbavier"
etc.....then send an email to the webmaster explaining what you want to do. He'll probably have to cancel the other user name.
Regards,
Rick
cbavier
Rick
Thanks I really have tried to change it several times but to no avail.
I Will do that.
Ayuh,.........
You Have to contact the Admin. to do it,..........
I went thru that to change the "B" in My name to a Capital letter.......
And I Agree,.... Posting an email addy on the forums is an Open Invite to the spammers,+ spambots...... Before We had IMs,.... I would only post mine for a couple of Hours,+ then edit it out.......
So Where's Chuckr,+ Why is he running his drive in the Trailer Position,..??..??..............:D
cbavier
So Bondo:
How do you contact the Administrater. I tried and can't find out how to do it. I've been all over looking through help and FAQ and cannot find anything. It's like they are hiding...Lurching in the background.
Do you remember how you did it?
:D :D At the Bottom of Every Page here at iboats is a "Contact Us" link....... :D :D
And I Think Delray,+ the Gang are still monitoring the Software Switch forum at the bottom of the Main page.......;)
cbavier
I had thought about posting it but that seemed like advertising. Know what I mean.
Thanks I see it at the bottom.....DUH!
