Out board Motors
mary ann
I have a 1990 Force 50 H P when running it doesn't have a steady stream of water from cooling pump. It has a spray or mist. Is this normal? Will this keep engine cool enough?<br />Thanks
bubbakat
Re: Out board Motors
try cleaning the hole out . may be obstructed
22WRF
You didn't say what the ambient temp or water temp was when the problem occured.<br /><br />If it's cold and/or the water temp is cold when you observed this, it just might be that the thermostat didn't get warm enough to open
