varuscelli
- Aug 31, 2009
- 8
Sorry if I'm posting in the wrong area, but this question seems more related to boat restoration than anything else, especially in terms of painting over something gelcoated (although I understand this post might get moved to the Non-Boating Technical Topics forum). In terms of a project, this seems closer to boat painting and restoration than anything I can find that's similar...and I'm finding precious little about the subject on any of the swimming pool forums I've visited.
I have acquired an old, fiberglass (gelcoated) swimming pool slide (deck only) that has not only a partially worn through gelcoat but that has also been painted over by someone using an unknown (to me) type of paint. The "new" paint (which itself seems to be several years old) has also been rubbed off and powdered away in places, but also adheres very well in other places.
The slide is 13 feet long and has an overall top surface area of right at 40 square feet.
There are a few chips and cracks (minor) that I am planning to fix with Marine Tex. I have also done a bit of sanding (by hand and random orbit sander) to see if the last paint put on the surface can be easily removed without damaging the original gelcoat any more than it already is, but it's evident that with sanding alone, that's going to be a difficult job. I might have to leave some of the old paint rather than risk too much sanding and extra damage to the original finish. Well...that or use something to try and remove the upper layer of paint without damaging the gelcoat beneath.
These slide decks (the slide itself with no associated hardware like ladder, legs, water distribution system) are roughly $1200 decks. This one cost me less than $100 and I'd like to keep my expenses to a minimum in restoring it. I don't mind spending money on the right paint and my own time sanding/patching/etc., but want to keep my expenses reasonable while doing it (not more than a could hundred extra dollars spent, if possible). I'll be doing a backyard/garage style restoration on this thing, so it's going to call for hand painting (roller and brush). Spraying is not an option for me.
Looking ahead to paint, I have somewhat tentatively narrowed my choices to something along the lines of either Interlux Perfection or maybe even Interlux Brightside (but I think Perfection is a better choice for longevity). Those seem to be good choices for someone like me to has to do this in a pretty basic DIY mode. I'm absolutely looking for advice on my options for painting.
Even though this is a slide...and kid's butts will be going down it regularly...it's a water slide, so even though bathing suit and skin friction plays a big part in wear and tear, the friction is lessened considerably by the water flow (just one more part of the long-term thinking). And, our pool gets only average use, so it's not like use on public pool slide or anything along those lines.
OK...that's my intro to the job. I am following up with photos of the current condition of the slide (the calico cat of slides, appearance-wise) and would love to get some advice on a best path to take to restore this slide with a reasonable amount of money and effort. Again, I don't mind doing the work myself...but I have to keep costs down as much as is reasonably possible and still get a good paint job. My only related experience is in refinishing furniture on occasion and one refinished and repainted fiberglass canoe.
By the way, my local swimming pool shops have been unable to offer advice on this project other than to use pool surface paint, and the manufacturer says they don't recommend repainting (manufacturer seems reluctant to answer any questions other that to refer me to a retailer for a new slide).
The slide (full length, 13 feet).
Closer-up images of the surface (very dark areas are where the slide was wearing through to the fiberglass or the top surface of the fiberglass mold or something; blue areas are the original gelcoat; and the whitish areas are the secondary paint job (unknown paint, unknown length of time since painting).
