ospray outboard (chinese yamaha )
chica w n
i brought boat with 15hp 2006 ospray 4 stroke (chinese yamaha) motor runs fine 1/2 throttle when you incress revs it pings and misses like little back fires
is there some way to time motor as this seems to be what it needs it runs fine untill you try to incress speed thanks for what ever you can give also can i buy a manual for this motor
JB
Re: ospray outboard (chinese yamaha )
If it is really a Yamaha get a Yamaha manual.
If the "Chinese Yamaha" is some salesman's claim about a knockoff I have no suggestions.
BruceAML
It would be helpful if you posted the correct name of your outboard. You have an OSPREY outboard not an Ospray. That motor is fully parts compatible with the equivalent Yamaha motor. Did you check the spark plugs? They should be BR6HS. If you have pinging the spark plugs shoud be replaced. Pinging is often caused by a lean fuel condition. I would look to debris in the carburetor. Are both spark plugs firing? What country are you in? Are you using gas of the correct octane?
