huntingtheworld
Thread starter- Joined
- Jun 13, 2010
- 254
1985 evinrude 60 hp Motor runs bad carbs are clean and timing is good.i noticed the float bowels are a different color then the carbs.could the orfice plugs be too small and from a different motor? And by that I mean the jet that screwed in the bottom of the carb bowel.It cuts out at half throttle if I bump the quick start primer it speeds up then it's fine.
