Orange fuel?
Roy Wirebaugh
I have a 59' sportwin that uses a pressurized tank. Im getting orange fuel out of the tank. I have taken the fitting off so I can pump the gas out. It will be orange for a few pumps then gets back to blue. I let it set for 5 minutes and it pumps orange again for a few pumps. Is there something I can do to clean this out faster so I can use the motor? I figure its the varnish in the pick up.....Thanks, Roy
seabob4
Re: Orange fuel?
Sounds like the effects of Ethanol to me...
Roy Wirebaugh
Re: Orange fuel?
Will the ethanol clean this out on its own and eventually stop the orange coloring of the fuel? Can I run the motor with the fuel turning orange or will it clog the filter?
seabob4
Re: Orange fuel?
Roy,
It is the Ethanol that is turning the fuel orange. You need to get rid of it, then use Sta-Bil or Startron fuel stabilizer with each fill-up...
Roy Wirebaugh
Re: Orange fuel?
The tank is clean with no rust. I can dump gas out of the tank and its blue. Should I keep pumping the fuel out as it turns orange until it no longer changes or just add the stabil to it now and run it?
duped
Re: Orange fuel?
Stabil is worthless. Star-tron corrects all ethanol problems, and stabilizes fuel. Spend a few bucks more, its worth it!
mike176
Re: Orange fuel?
Just put a filter on it and run it or you could do some off the wall stuff like others might say here. You got rust in the tank.
