Optimax & Alpha1 hub compatibility
250Gimp
Hi all
I am looking at a used Merc prop, and it comes off a Merc Optimax OB, and I want to put it on an alpha 1 gen 2.
Is the Flo Torq 2 hub the same for both, or do I have to change the hub out of the prop?
Thanks for the time!
Re: Optimax & Alpha1 hub compatibility
Ayuh,... If it's a Large gearcase outboard,...
The prop will swap, No problem...
250Gimp
Thanks a lot Bond-o!!
I thought it would, but wasn't sure.
Cheers
rpr
Similar question.
I am looking at a slightly used prop that was hubbed for a Mercury Alpha 1 drive.
I have a 2007 Mercury 250 ProXS, which I believe has the "fat shaft" prop shaft design.
Will I be able to use this prop without changing the hub???
250Gimp
YOu may want to post a new thread for this question.
Afraid I can't answer it.
