Optimax 200 02 oil failure
BarflyRIB
hi,yesterday after 2 months of no ribbing, we went on sea... at home I started the engine, no problem at all and starting at the first fire!!
after 20 min the smartcraft starts beeping four times and repeats that every 2 minutes... 2 symbols were on, oil and engine.
I immediately shut down the engine and the checked the seperate oil tank (was full) and also the engine oil tank by screwing of the cap, was also full.
Getting back and checked at home, the engine oil tank was still full.
what can it be? bad sensor? oil pump died?
j_martin
Re: Optimax 200 02 oil failure
Yes
Best bet is to get the maintenance manual for the engine and go through the oil system maintenance analysis procedure in that manual.
hope it helps
John
