bushpilot47
- Jul 6, 2013
- 2
I have a 2004 Optimax 135 that ran fine last summer. When I go to start it this summer it won't crank over. I have replaced the batteries and battery wires. I have a 9.9 hp Honda trolling motor that is the same. clicks but won't turn over either. Same batteries. Also the tilt motor only hums when I try to tilt it. The "Smart gauge" (tach, hours, temp, etc.) shows 0.0 volts. The battery gauge shows 14+ volts. The voltage doesn't drop at all when I try to crank it. Connections on both outboards seem clean and tight. Since the problem is the same on both, I'm thinking something other that the engines. Out of ideas. Help!
