I have a 2008 Mercury Optimax 115 with a near new impeller changed this spring(reputable dealer) and it has less than four hours on it. On my last two trips within minutes of shutting down from 4500-Max RPM to idle at 750 RPM the engine begins to overheat and a warning signal activates. She won't do it at 1500 RPM or above, just at near idle. The water discharge is light at lower RPMs, I cleaned it from the discharge hole back a few inches without improvement. I'd appreciate any advice that you may offer; she's still under warranty!
Thanks!
Thanks!
