optimax 07 overheating
jmoe
I have a 2007 115 horse power optimax that I just replaced the water pump on. It is still not putting out as much water as beforeand the alarm will go off after just a short run period. I noticed setting at just an idle that there are bubbles coming up from the outdrive. I was wandering if maybe the tube from the water pump was maybe not hooked up right causing the bubbles?
