optical sensor
gotmeaboat
1994 Johnson J150EXERV
if i change the sensor, will this change the timing?
tom
Fl_Richard
Re: optical sensor
It shouldn't if your very careful. You can replace it without touching the flywheel or timing. I would still check the timing to ensure nothing moved but you should be fine.
