I have a 2001 Johnson 150HP outboard with an Optical Ignition System 2000. First time I took it out it ran like a charm. Second time I sucked up a little water from my tank and had trouble. Was able to get out the water and the engine ran fine the rest of the day. After that trip I drained the tank, completely dryed it out, changed the fuel/water separator filter and filled the tank with clean gas. I also installed new plugs.
Upon putting the boat in the water I had a hard time starting it. When I finally did start it (I think maybe I had flooded it) it idled normally (1000 RPM) for about 30 seconds, then revved to about 2500-3000 rpm for another 30 seconds, cut back to idle and died. This was followed by difficulty in starting and more of the same (idle-rev-idle-die). At some point I pulled a plug and held it against the engine to look at the spark. The spark looked kind of weak.
Upon getting the boat home I went thru the OIS 2000 troubleshooting guide. At this point I believe I may have a bad powerpack.
My primary question is this: Could an ignition issue cause the idle-rev-idle-die scenario that I experienced? I checked the fuel filter and it was completely clean. Drained all carb bowls and they were clean for the most part.
Any comments would be appreciated!
