Opinions?
Bry21317
I have an 88 Force 125 HP engine, that has always given me problems over the yars with the T/T. Every part of it is brand new basically, excpt my pump on the motor has a problem now. I am unable to find this part, other than a brand new new model for it that costs $600. I don't want to spend the money for that. <br /><br />I have found that I can purchase from a shop here installed a CMC Jackplate, with the T/T built in. This will also give me a 5" setback. The model is PT 130, the guy said it would run me $600 installed. Is this a good price? If I were to sell these parts on Ebay for my original Tilt and Trim, about how much should I get? The main trim cylinder is basically brand new. It was purchase last year, and not hardly used but about 10 times with the boat in the water. Never taken this boat to salt water. The Tilt cylinder was rebuilt about 2 or so months ago. I am thinking of fixing the pump now, by taking it to a machine shop to have the hose connections rethreaded so that it will work. But I then think that I will get rid of this, and put the CMC on, so I dont have to worry what it will be doing in a year or two.<br /><br />What do you guys think?<br /><br />Thanks,<br />Bryan Cox
D
DJ
Guest
Re: Opinions?
Bry,<br /><br />The CMC is a good product. At $600.00 installed, that is a good price.<br /><br />You may have to do some reconfiguring once you try it out. Depending on your hull, you may have to move the engine up a bit for best performance.<br /><br />I would search on e-bay for proposed prices of your parts. I see Force trim parts on there quite often.
Frank Martin
Re: Opinions?
have a good used cnc tilt unit i woul like to sell was used in fresh water only and is two years old 300$ PLUS SHIPING cALL FRANK 708-862-2407
Bry21317
Re: Opinions?
Frank,<br />What is the model number that you have for sale?<br /><br />Thanks,<br />Bryan Cox
