Well finally got my boat back together and I've got some questions about the operating temps. I replaced the temp sensor, hoses, thermostat.
Now, I don't know much about risers, but it appears the risers have separate chambers? Is that correct?
The thermostat is 143 degree thermo. What should the running temps of the risers (each 'chamber') be (approximate) and the temp of the manifolds?
Also, what is an acceptable difference between the risers (port & starboard) and the difference between the manifolds (port & starboard).
I seem to have about a 25 degree difference between port and starboard sides on the manifold and about the same on the risers.
My port manifold seems to be about 150-155 degrees, my starboard manifold seems to be running about 175-180 degees.
My port riser where the water goes in seems to be around 110-125 degrees, the starboard riser where the water goes in seems to be around 80-90 degrees.
The water coming out of the manifolds seems to be about the same temp - 130-140 degrees.
I'm using one of those infrared thermometers.
Thoughts?
Thoughts?
