Open fuse panel
stevieray
Noodling around under the instrument panel on my 1988 23ft Celebrity, I see the fuse box is just an open panel - no cover or lid or other protection from the atmosphere (except that it's under the instrument panel). The fuses looked like they were getting a little corroded, so I replaced them all. Should I slather the whole thing with WD40 (fuses, connectors & all) to prevent future corrosion or is there some better way short of replacing the whole deal (which may mean a lot of re-wiring work).
Any i-deers?
stevieray
Re: Open fuse panel
I pulled all the fuses & squirted the WD on everything - that should get me thru this season. I will put the panel replacement on the list of projects for the fall. Thanx for the recommendation.
