Only runs with the starter engaged
Bones138
Hello need some help,
I have a 89 Bayliner with the Ford 2.3 4 Cyl. The starter was bad and has been replaced. This is the first time I have tried to start it this year. When the starter is engaged the motor seems to run. When you let off the key from the start position the motor dies. someone said to replace the starter solenoid which I did. There is spark at the coil when the starter is turning the motor over and it is getting gas in the carb. but the motor will not stay running. Not sure what to do next. If anyone can help. Thank you
Monte1961
Re: Only runs with the starter engaged
You have a start position and run position in the ignition system. somewhere along the way, you have lost run position.. Heres what you can do. Take a 12vdc test light and check for power when on run only and trace from there. fuse blown, wire broke or missing, ignition switch bad or loose. post back and let us know what you find!
Bones138
Thanks Monte
found a wire that was hooked up to the switch but broken inside the connecter. Put a new end on it and fired right up. thanks for the help
