Only going forewaed
Lostmygirltofish
I have a 1991 johnson 120hp, model number is J120TLCCA, when i turn it on it only goes foreward when i idle and when i put it in reverse, but i guess thats better than reverse. Have no other problems with the motor besides that. Any ideas would be much apriciated.
thanks,
tashasdaddy
Re: Only going forewaed
have you check the shift cable? the shifter? the shift linkage connector? have you disconnected the cable at the motor, and tried shifting manually?
Lostmygirltofish
I took the top off the motor and shifted it in reverse and when it goes back it gets too a certain point and then it kicks back foreward. Also is it normal to see a little gas in the water when you stop like a film in the water. I'm trying to figure out if i have a slow leak, becasue i put 10 gallons of gas in the boat and probably ran about 10 miles and ran out of gas. Does it burn more gas if the oil is out or low? I have 16.9 foot Hydra Sport flats.
Thanks for the help.
