thank you . when i put back together and ran it. about two min dribbleing after it got hot good stream of water. let cool down same thing just dribbled warm up good steam on and off water very hot comeing out of motorThe first thing to do is to make sure that the tube coming from the block is clear as mud daubers love to get up in there and block the pisser line. Use a length of lawn trimmer line and get it up in there as far as you can to make sure that it is clear.
Gerry
Gerry
i didnot know it had to get hot for a good stream. 90 hp mercury i had turn water on start motor good stream right off the bat . but i learned how to change a water pump.Yes, it will take a bit of time allowing the thermostat to warm up to 120 degrees before it opens and allows full flow out the pisser.
Gerry
