One gear works, not the other... '76 115 Johnson
jdk81
Hello,
I have a 1976 115 Johnson Outboard I am having issues with. The motor starts and runs perfectly. When it was parked a few years ago everything worked perfect. I am now looking to sell the motor and had a seal kit put in the lower unit.
I can move the shifter linkage (on the motor) in the down position and I get prop shaft spin. when I raise the linkage it wont just click into gear. The harder I pull I can get it to slightly spin, its like the clutch just wont quite engage. I am not sure if there is an adjustment for this somewhere that I missed?
Any questions you have post them here and I should be able to answer quickly.
I am looking for any help I can get.. I'd like to get things working perfect so I can get the motor sold.
Thank you!
Thank you!
emdsapmgr
When you had the lower unit off, did you do any adjusting to the shift rod? (it screws in/out) Likely you had the rod out during the reseal of the lower. Upon reassembly of the lower, it's very important to re-establish the exact height of that shift rod. The factory has a measurement spec which has a very narrow tolerance. If the rod is out of spec, it won't shift properly once it's put back on the midsection. You can perform minor adjustment at the top of the engine-by turning the thubwheel on the shift cable. If that won't correct the shift problem, you will probably have to drop the lower to reset the shift rod height.
jdk81
Thanks for the advice.. this is exactly what my motor guy told me. I was able to spin the shaft without dropping the lower unit... got it shifting properly now!
Thank you
