Re: Once and for all!
More complex because the rotation of the blade is circular so it depends where the grass is w.r.t. the blade at time of impact. So, for example, the grass that is struck at a right angle to the blade on the left (assuming CW rotation of the blade) will be struck by a blade with a velocity of 53 Mph parallel to the direction of travel of the mower.<br /><br />The grass directly in front of the mower will be struck by a blade going 50 Mph perpendicular to the travel of the mower plus a force of 3 Mph parallel to the direction of the mower. The net vector velocity will be 50.09 mph at a 79.2 degree angle to the direction of the mower (so because the mower is moving, the strike isn't exactly at 90 degrees like it would be if the mower wasn't moving)<br /><br />So, you do the same thing basically for all the grass struck by the blade. Assuming the blade rotates clockwise, the grass parallel on the left gets struck with a velocity of 53. Those struck on the right get struck with 47. etc, etc<br /><br />Gosh, I haven't done this stuff since the mid eighties! I'm getting OLD!
