Onboard Charger Questions
TheChad
Hey All,
I have a 24v system on my boat, with a Guest 5/5 Onboard charger.
When I plug in the charger, should I be removing the battery caps?
Should I plug in the charger, and leave it pluged in over the winter?
How often do you normally check the acid/water mix in the battery?
Thanks,
-TheChad
DangerDan
Re: Onboard Charger Questions
Unless your doing a rapid charge I don't see a need for removing the caps. When keeping a charge on my batteries in a "maintenance mode" I don't bother with removing them. Every fall and spring I check the water level in my batts and add distilled water if necessary. Other than that, I just leave them plugged in for the winter. Going on 5 years for the same three batts now.
Silvertip
Honorary Supreme Mariner
I do the same. Plug it in and check the cells periodically. Never had to add water in the past but it never hurts to check.
JUSTINTIME
the battery will vent normal, but before pulling it in check the level of fluid in the battery
