Re: On PTT, one ram lowers while trimming down
I thought of somthing else, make sure the manual release valve is fully closed.
And when you filled it .
Did you install plug, and cycle down and back up , checking fluid on the fully up position, refilling to threads in hole.
If not , try it this way .
Doing the same thing , at least 5-6 times.
You can do a pressure test , but it requires removal of the unit, and you'll need a guage.
Id save it for the last.
We had a problem , similar to yours years back.
And for some reason , it was a bear to get the resevoir full.
If you dont have the procedures for doing a amperage and current draw test.
Shoot me your email and I'll send the info. to you .
Too much to type.
Make sure you check everything else first .
All connections , switch , wiring, solenoid, etc. etc.
The motor can still run, but not be able to draw the necessary amperage to work properly.
As I said I can scan and e-mail the tests, as stated.
As well as all the tests for the whole system .
Really though , if you don't have one, you need to get a manual.
That is if you want to fix it yourself.
Just being able to use part of the stroke is not working.
But a sign of trouble coming. Need to get it corrected first.
One component failing/ weak , can cause damage to others , in an electrical circuit.
Due to incorrect, current draw , surges, etc. etc.
KYHunter
