RebelCobalt
Thread starter- Joined
- Sep 27, 2010
- 14
So the saga continues on my '98 VP 5.0Gi. As a reminder, this is the one with no compression in cylinder 1, allegedly due to it having too-short spark plugs. My first mechanic told me I needed to buy a new long block...
I'm on my third mechanic now, and he has got my boat running. He hasn't run a leakdown test yet, but he cleaned out the throttle body (full of fan belt dust), put new (and proper length) spark plugs in (the current ones were old and rusty, and one had blown the electrode), and changed my distributor cap (the old one was full of corrosion), and apparently it now runs OK.
Compression in cylinder #1 is lower than the others (50 compared with nearly 100), but that's better than when he started, and better than what the other two mechanics told me (close to 0). So he ISN'T recommending a new engine block, like the first guy, thank god...
So my new mechanic has recommended I just run the boat for a while and check-in in 12 months' time to make sure the compression is OK (he seems to think it will get better as I run the engine).
My questions are - will running it (when I know the compression is low) do any harm to the engine? Is it still worth getting a leakdown test?
