Omc will not start and stay running
joe l
5.7 omc will not start. When I turn it over, it revs up for about 3-4 seconds and dies. I have checked timing alinement, checked fuel pump, replaced distribitor, changed spark plugs disconnected the shift interupter and nothing seems to work. Also someone said to disconnect the tack, did it and still nothing.We checked the spark on each plug while turnning it over and it seems to missfire on very second plug. That is why I disconnected the three :mad: plugs to the interrupter. And you know the rest it will not start. I am running out of patience and summer.
Re: Omc will not start and stay running
Is it getting any Gas ????
joe l
Yes it is getting gas. I even pured some in the carborator and nothing. When you prim it with the shift lever you can see the gas going in the carborator when it is being turned over.Also I checked my water seporator and nothing.
