bajaunderground
- Apr 18, 2008
- 1,401
Re: OMC/Volvo Penta Planing issues?
I did that yesterday, and with the throttle (control) opened all the way (in neutral) it only opens about 80% of the way...now that I think about it, that's probably a safety design thing...maybe I should have it in gear, then do it? Choke is not in the way, there's a cam between the carburetor and electric choke that opens the butterflies the remaining ~20% (or doesn't allow it to open beyond the ~80%, I'm assuming until it's warmed up?) Maybe I'm I'm running too cold? Maybe the thermostat is stuck open? I run between 120˚-160˚ on the gauge...the risers are always hot to the touch, but not so hot I cannot keep my hands on them (just thinking out loud here)
So, with the engine OFF, and in forward gear:doh:, open the throttle fully,,, Then go back by the engine, & look down into the carburetor, and see if the butterfly's are opening all the way? If the choke is in the way, open it manually for now (that would be another issue to check later).
