narmstrong26
Thread starter- Joined
- Aug 14, 2009
- 7
Hey all I was looking around the forums for how to add a Faria tach to my 115 V4 without any luck. The instructions from Faria just say you may need a voltage regulator kit. No one that sells the tach has ever heard of it and Faria isn't much help either. After mucking around a bit I figured it out. For most V4 Cross flows 115 (I don't know about the 90 but I would assume the same). You need to connect the signal post to the Grey wire leaving the regulator. The battery feed to the purple wire (or a switched source) and the ground to ground of course. Set the pole setting on the back of the tach to 5. On my engine a 97 there is a terminal strip on the left side of the engine that has the gray wire about 4th wire down and the purple wire at the bottom. I have heard on older engines you may have to dig the gray wire out of the harness and tap into it. That should be it wired up and going.
