Omc turbojet 115, need info
Nitr0enngiex
Hello I am new.
I got a 94 fling on trade and i assume it has a 115jeer engine. I tested compression and it is appalling at 70 to 85 among the 4 cylinders.
I already ordered 2 carb rebuild kits but I'm thinking i will need to rebuild the engine. I am sure the compression should be well over 100. where should i buy parts from and if anyone can tell me what exactly i need to rebuild.
I am assuming at the least i need piston rings And head gaskets. I would plan on having the heads shaved and maybe a hone or bore.
Whar else do i need to know? Anyone have a pdf of the service manual?
I plan on premixing gas when i get it running. I found it has a small electric fuel pump but the fuel still routes through a canister which i believe is the oem fuel pump which is not even wired or plugged in so i think i can delete that maybe.
I ordered new ngk plugs, two sets, one to keep in the boat as i know 2 strokes can foul plugs easy. I also want to try and clear the gas tank and fuel pick ups.
I just want the fuel system perfect and fix the compression
After reading allot on this board i will also go through the entire cooling system.
boobie
Run another compression test with a different gauge before running off into the heat of the day.
Honorary Supreme Mariner
It is the same powerhead as a Johnson / Evinrude outboard of the year.------Fuel system of course has to meet " inboard " rules and regulations.
