omc trolling motor resistor question
tsp21367
In the process of replacing the resistor I pulled the ring connectors from two of the wires. They had, what seemed to be, extra thick shrink tubing on them. My question is will any shrink tubing work in its place, or is there a specific reason for this thicker tubing? Also should I try to seal the threads on the shaft or is the rubber washer good enough? THANKS!
HondaPower
Re: omc trolling motor resistor question
I have the complete pages describing the procedure with pictures. There are two separate instructions, one for the HBF2 model and one for all except the HBF2 model. Let me know which one you need.
tsp21367
Thanks for the reply but I got the info I needed from a local mechanic.
