OMC stringer bolsts up to what motors?
Sporaticus
what motors bolt up to an omc stringer, and in theory a 351m and 400m should bolt up to a king cobra right? they are after all the same bolt pattern as a 460 ford for the c6 small block tranny. would be nice to here that one of those bolt on to a stringer though i highly doubt it.
Re: OMC stringer bolsts up to what motors?
I Think the Biggest Problem with doing what you wish to do is Not the Bellhousing Bolt Pattern,<br />But,<br />The Exhaust Manifolds..................
Sporaticus
hmmm<br />they dont make marine exhaust manifolds for the 335 sereis of heads at all?
My last post contains Almost All of the Ford Knowledge I possess...............<br />I'm a Chevy Man........<br />Well,<br />Except for my Ford Diesel Pickup........<br /><br />I've seen exhaust manifolds for 289s, 351s,+ 460s............
Sporaticus
do yu know hat kind of 351?? 351C 351W 351M???
Windsor..............
Sporaticus
:( surely theres been a boat with a 351c!! theres gotta be.
rodbolt
hahahhah<br /> a stringer unit will puke like a drunken sailor when you hit the throttle with a 460 ford. the cobra drive was marinal and the king cobra and Bravo # drives handled it well. dot even try the 460/stringer combo. but if you must you will need the shft coupler,manual shift flyheel and the proper bolt pattern intermediate housing. all should still be around.<br /> good luck and keep posting
steve n carol
Hey sport! thinkin' about puttin' your truck engine in there? when I bought this last boat, the sellar was proud and sure that it was a 351c. he was more shocked that I was when I told him it was a 302. <br />be careful about using a 'non marine' engine in your boat. If this is what you have in mind, search "auto engines" in the search engines.<br />BTW, lots of 460's in jet boats!...sl<br />P.S. I do believe the C-6 is a Big block tranny...sl
Sporaticus
my enternet went out for a while so I couldnt check up on this tell now, thanks for the help guys, as for c6 being a bigblock tranny there are two c6s big and small block, only difference is bolt pattern, and i wasnt even thinking of putting a 460 on a stringer lol, was thinking of putting a 400m or 351m on a king cobra
steve n carol
Sport a cuss, <br />How about a jet drive? Jacuzzi, Berkely, to name a few.
