chiefalen
- May 18, 2008
- 3,598
Re: OMC Stringer 800 serial #'s decoding
W.O.T 4200-4600 rpm's is what he book says.
So your right in there how fast you going?
You can use a gps to verify cause the boat speedos are never right.
And if you wanted you could hook a shop tach, and verify rpm's
Redoing the drive nice winter project.
You will need a very long piston ring pliers.
Or do what i did get a real long like 13 inch needle nose and grind down the tips to fit the ring on the bottom of the prop shaft.
If you run into a problem just post.
Your gears might just be right cause i re-read your last post your in the groove rpm wise.
You could always go down a pitch will give you another 2-4 hundrend rpm but will hurt top end.
Good luck
Good luck
