ryanorr280
Thread starter- Joined
- Jun 28, 2007
- 21
hi, my name is ryan, i am new to the forum, and would like to say thanks for all the information i have gotten with searching here. i have a 88 balyliner cobra 2250, 5.7 OMC cobra, i got it at end of season last year. it had no reverse and a leak into hull. had a boat shop adjust cables, now has reverse, with no forward(had it before). took it to another shop, they say it needs a lower unit due to gears. quoted like 4k to replace it, i decided to mess with it myself. i believe leak is coming in around transom, i have transom gasket kit, bellows kit, lower shift cable(read post that describes adjustment, found mine to be stiffer than 2.5 lbs) ordered. my main question is will i need to re-align engine after removal for transom seals, or will it sit back in original position, and do you think in your opinion the gears are actually bad, or just needs adjustment? sorry post is so long, i just wanted to let you know what i do about history of boat, thankyou in advance.
