OMC Shift cables frozen
utdcg1
One of my 1986 Sea Ray (28' with twin OMC 383 engines and outdrives) shift cables is frozen solid. First indication it was hard to put into reverse. Now it won't go into forward or reverse. With the cables going into the outdrive disconnected, the cables do not budge. Tried squirting some penetrant down the cabe housing but no luck. Is there something I can do that may help without pulling the boat out of the water?
Thanks for any help!!!
HT32BSX115
Re: OMC Shift cables frozen
These are Cobras?
If they are they probably need the lower shift cables to be replaced.
You can determine if it is indeed the lower shift cables by removing the drives and operating the cables without the shift plate connected. But the drives have to come off. With the drives off the cables should move pretty easily.
How did everything look last year when the drives were removed? (or should I say, when were they last removed for service?)
If they're Stringers, someone will jump right in shortly!
Regards,
Rick
Ayuh,....
Replacement is your Only Option.......
utdcg1
As a follow up...I kept up with the penetrant and they finally worked loose and i havent had any problems since. They are Stringers...and the past maintenance has not bee very good by the previous ?? owners...
chiefalen
Sir; stringers are the last drive i would leave in the water over a summer.
When you do pull the boat for the winter who is going to do the oil changes and such for you?
I would like to know when it does occur please keep us abreast of the developments.
Thank you and welcome aboard.
THE BEEF
HEY! I have a stringer, I kept it at Beef Creek Marina for the last 2 years ,no problems. I just change all the lubes at the end of the season.
Beef
chiefalen
Ok beef, you don't get water in the clutch housing?
THE BEEF
Chiefalen
I know you won't believe this but no I don't get water in the clutch housing.
I use the blue synthetic lube in it.
Thankyou..... Now I have brought the dreaded Triple pecker pigeon curse on me!
Beef
