OMC sea drive tilt/trim
txmink
tilt motor went out with motor in down position. Manual only states how to lower the motor not raise it. Does anyone know how to raise the motor manualy so I can tow it to shop for repair?<br />We used the good switches to test the tilt on suspected bad one from our other motor.
TLH101
Re: OMC sea drive tilt/trim
On some Sea Drives the release lock valve is accesed from below the the unit. There is an access hole near the forward edge of the botton mount cover. Use a large straight blade screwdriver and turn the valve counter clockwise. If you cannot get it open, you will need to remove some covers and disconnect the lines from the cylinder.<br />BTW the unit is very heavy and will need a couple of guys or a jack to lift. Remwember you are lifting the whole motor and bracket assy.
txmink
Manual states the release valve is lower only. Lifting is performed thru this method also?
GatorMike
Ensign
txmink, If you losen the screw in the access hole TLH101 mentioned you can lift the motor by hand. You will need an extra large screw driver and it may still be a bear to break lose.
GatorMike
Ensign
Something else you might try, if it is a switch and not the motor that is bad. Unplug the green and blue wires that go to the tilt motor and touch one to each pole of a batery. Be careful because you won't have a fuse in that circut but if the motor is good and the switch is bad you can raise and lower the motor that way.
Solittle
OMC shop manuals are still available for the SeaDrives. I have a pair of 1987s.
txmink
Originally posted by SoLittle:<br /> OMC shop manuals are still available for the SeaDrives. I have a pair of 1987s.
I have the manual
txmink
Originally posted by GatorMike:<br /> Something else you might try, if it is a switch and not the motor that is bad. Unplug the green and blue wires that go to the tilt motor and touch one to each pole of a batery. Be careful because you won't have a fuse in that circut but if the motor is good and the switch is bad you can raise and lower the motor that way.
txmink
Originally posted by GatorMike:<br /> txmink, If you losen the screw in the access hole TLH101 mentioned you can lift the motor by hand. You will need an extra large screw driver and it may still be a bear to break lose.
****Will romoving the plate covering the access hole help any?
txmink
Will removing the plate over access hole help any?
rk21
i just picked up a 1983 omc 115 1.6lt outboard......it seem the person prior to me didnt have it hooked up right.there isnt any tilt or trim buttons on the shift lever and the round switch on the dash isnt hooked up either.....the wire from the shift lever goes to motor and there is a relay box on the ill say the back side of the motor...there is a five hole plug that isnt plugged into any thing...and then there is a black and white with red it appears to be cut then also the 2 wires that go to the the the plug thta goes to the trim motor from the relay box.....first time dealing with tilt/trim and im really lost......i saw one motor that was the same and it didnt even have that relay box there at all......any help would greatly appreciated.thank Skip
Auxlarry
This must be Seadrive T/T problem week...lol
I just had the same problem with mine, stuck in the down position and couldn't move the boat. Couldn't get to the relief because you couldn't access anything with the engine down.
I removed the cover (vertical cover with the 4 screws that is attached to the pivoting mount) attached a lift to the lower unit and could than access the four bolts that hold the trim cylinder to the motor bracket, removed the bolts and was than able to lift the motor and block it with a 4x4 for transport. Once this trunion is removed you can lift the engine very high, just make sure your wires and fuel lines don't get snagged or pulled to hard while lifting.
Good luck!
Larry
